Hi i think the fuel solenoid on my kzn130 is playing up, for example it will start and run for 30-40 secs then stop, belt the solenoid with a hammer then it'll run fine until you switch off then it's the same over again....i can't seem to find a spanner or tool that will remove it so i can replace it, has anyone changed there's and where would be the best place to buy a replacement...thanks Ian
