Just fitted new front bearings,discs,flexis,short pipe and calipers to the 4Runner. Everything was fairly straightforward.Bled it all up and tested it, rock solid pedal, job done methinks.
Anyway, gets half way home from my mates garage and the pedal starts going spongy. Gets home, no leaks from the front. It has developed a leak at the rear, the hyd oil runs along the top of the diesel tank above the rear axle and drips from there.Suppose the increase pressure from the new stuff sprung the leak at the back. My question is, to the clever people on here, is that a flexi up there,straight pipe or a union?
Taking it back tomorrow and a little advice could speed things along. It also looks, from an initial look, a right bugger to get at, any tips would be helpful.
Thanks in advance.
Thanks in advance.
