Firstly, One of the sheets of paper I have with the car when I bought it says that it is a KZN185. I believed this.
Today I looked at the plaque in the engine bay and it says KZN130 on it. Should I ignore the piece of paper?
Secondly, While hunting for a new starter motor I noticed a few have stuff about a code on them with lots of numbers then a dash and then 4 more numbers. I cant find this on my one, do I have to actually scrub it clean and get in there with a torch or am i being a tool?
Thirdly, my near side front CV joint boot seems to be unattached at the bit where it goes onto the drive shaft thing coming from the engine area. Would it be an idea to get hold of a new one and rip the old stuff out? It's sprayed grease and gunge all over everything under there and makes some noise on full lock.
Fourthly, My document with the car says it was built in June '94. This is fine but EVERYTHING I look at on ebay seems to be up to '93 or from '95 to whenever. By looking at pics of everyone else's and what they've been saying, I've worked out its a 2nd gen so does this mean that I can use bits that say '95-'x or should I look more at 'x-'93 stuff for example.
Finally, how many bolts are there in the starter motor in this car? i can only see 1 and have a feeling that's not enough.
All wisdom massively appreciated
Alex
Alex
