Hello (again) I've had a metallic grinding noise develop today and after a quick look underneath the rear propshaft where it joins the rear diff has some play in the UJ.
Here's a piccie of it:
So I'm assuming that it will need changing and this will (hopefully) sort out the noise. Could anyone tell me if this item is the thing I need to be ordering:
http://www.roughtrax4x4.com/?doc=16&cid=163&vid=192
Also a sneaky bonus question now that you're here, I recently changed the fluids in the auto box and the front and rear diffs, however it appears I must have missed one:
These look like the same drain and refill bolts on the diffs so I'm assuming there's fluid in there that needs changing. Is this called a transfer box please? If so I'll have a search for the correct fluid for it unless someone is able to advise what to put in there.
Thankyou very much
Thankyou very much
