mystery noise
Yeah, only M10 with a big washer, I thinkOriginally posted by Wolfracer View Post
That's some safety bolt then!
it's to stop the drive shaft pulling back out
of the hub, don't know why, it can only
come out if the ball joints fail as far as I
can see. (then you're in trouble)
Gman.Last edited by GRASSMAN; 18 July 2011, 23:19.If it aint broke, keep goin' till it is.
everything above checked + more and still the rattle.....
i thought i'd update this thread as i hope i have found the answer,it seems these bronze bushes may need replacing,
Tony mentioned in the 3rd post but i was still getting it in 4wd
http://www.hiluxsurf.co.uk/showthread.php?t=13771
fingers crossed
anyone done this fix?
cheersLast edited by subtotal; 8 October 2011, 15:49.
Got the same noise....thought it was the bronze bushes but it's something I don't know the name of...yeah useless bit of info I know!
I can tell where it is though and maybe later I will find a diagram of it..
When you take the front wheel off, then the disc you then have the upper and lower arms. These you need to separate to get the drive shaft out.
On doing this I found attached to the underneth of the upper arm a smallish bracket/bush/link thing about 3-4 inches in size and sort of triangular in shape...it was this making the metal dink dink noise like a little man with a hammer.
Rubbish description I know, but it sounds the same plus everything appears ok when you check...... Which was nice.
Did my Bronze bushes on the drivers side about a month ago.
I had a rattle going over uneven surfaces, old cobbled roads where the best example.
Replaced outer and inner bushes drivers side only - rattle gone, no signs of wear on old parts.
thanks Tony i had the bushes changed this week and it was these that needed replacingOriginally posted by TonyN View PostTry and find a reasonably straight bit of road, then put it in 4wd and see if the noise goes away. If its does then its your front hub bushes.
and thanks for all the other replys
cheers
