Hi guy's
I thought I had fixed this fault but no luck.
Starts from cold OK ( I usually start on Dino switched over the night before) runs at any speed, any engine revs, for up to about 5 miles then if I let the revs rise to about 2.5k the engine check light comes on and power is very limited, revs is limited to about 2.5k
From here on if I keep the revs at about 2200, no problem, I can drive all day I can even get up to 65 like this. (Its the low gear hills that are a problem)
As soon as the revs go to about 2500 engine check light on I then have to throttle down way below 2k for about 6 secs and the light goes out, full power is then restored until I hit 2.5k again... and so on.
One of the error14 faults is blocked filter but I have changed them also removed the top of the injector pump and blasted everything with the air gun (including removing the filter behind the fuel temp sensor).
Once the car gets into this error condition it remains so until everything has cooled down for several hours.
It faults on both BIO and DINO they both have their own filters (the bio has a total of three) only the changeover valve is common to both.
There are other causes of error14 but I dont totally understand them or where to check.
any idea's????
any idea's????
