i have noticed the past week theres a fair bit of water coming from the air con drain through the pass side bulkhead,its making a saucer shaped damp patch underneath the drain when its parked up.
i started taking the dash/air con unit apart but it seems impossible to take apart unless you dump the gas and split the pipes,pull the dash back and take the box out complete,am i correct?
the coolant is down a little but the water coming out the drain is very clean.
im a bit unsure as to how much water should be coming out so can someone advise me please?
