Here goes, I've been getting a distinct diesel smell for a while, hadn't had a chance to take alook and as everything was running fine thought i could leave it alone.
I started having trouble starting it a few days ago, usually its half a crank and off it goes, its started really needing a good grind to fire up, engine is spinning fast, batteries at 90% so a bit of trawling and i think its the primer. doesn't get hard no matter how long its pumped!
I thought I would also check the drain valve as the engine bay looked a bit clean around the filter. Unscrewed a couple of turns by hand, re-did tightly but still by hand.
Only now when I prime the filter its dribbling fuel out of the valve at the bottom. Before I start buying things are there any o rings or something I could have unseated and would this on its own account for the primer losing pressure?
So new filter and.....what?
I have to mention I need to get everything in one go when I'm in the UK in a few weeks as parts are non existent here and postage is a killer.
