Hi All,
A mate of mine has a 3.0 four runner? (UK surf) and the oil guage is showing very low pressure (just of the bottom of the lowest mark). Are the guages reliable? As the motor seems fine, and is the oil light also to do with pressure or is it oil level? The light comes on with the ignition then goes out when engine starts and doesn't flicker at all, even when you try to stall it.
Hope you can help.
Mark......
Hope you can help.
Mark......
