Hi,
Again, I have looked through the many threads about 4wd issues on 3rd gen Surf. Basically, when engaging 4wd, the light flashes but never settles and I can't hear the distinct clicking of the transfer box/diff. You'll have to forgive me, my knowledge is somewhat limited.
I have lifted the front passenger side wheel and it turns freely with the 4wd engaged and disengaged. I've looked underneath and all connections seem ok. Both driveshafts turn when 4wd is engaged but only rear when 2wd is. Hard to do as I'm alone here and having to check the vehicle driveshafts while nobody is at the wheel is a bit dodgy.
The other day, I engaged 4wd to go up a steep grassy bank and the rear passenger side just spinned despite 4L being engaged. The last time I know it worked for sure, I was extracting wood from a coppice so the back was fully loaded. I remember that once I was back on tarmac, it took forever to disengage.
Any ideas anyone? I know it's all a bit vague but some directions would be greatly appreciated. Thanks.
