Viscous fan oil replacement
  • #31
    Originally posted by Wolfracer View Post
    Damn! I knew it seemed too straight forward! So, it's demount, take apart, pour out old oil, bathe in petrol,(overnight?) then re fit? Looks like another weekend job then!
    Thx for info.
    That's the way I did it. I'm not saying it's the best way or the only way.
    If you use petrol, remember to remove the sealing ring!
    • #32
      Okay thx, did you dip both halves or just the clutch half?
      www.johnthebuilder.info
      • #33
        Both halves, it's pointless doing just one.
        • #34
          I did as albannach, with 50ml of 6000cst.
          Only problem was once I'd removed the seal it expanded so I had to cut it to get it back in.
          • #35
            Hi there where do you get the oil from please?
            regards
            tom
            • #36
              Try hobby shops with RC Cars. Toyota should have it also.
