Mechanical f***wit here.
I've taken the timing belt cover off and I understand that I need to align some marks.
From what I've read I need to turn the cam sprocket (the large 19mm nut in the middle right?) to line up some marks. (Engine is in neutral)
Which way do I turn it? Clockwise or anti? I'm thinking clockwise but wanted to check.
Pics I've seen from others seem to have the tippex marks lines up with the centre at the top but I guess that I just need to see if the marks all line up on this and the fuel pump ?
Theres two lots of marks on the teeth of the cam sprocket so I'm guessing that the tooth with the notch out of it lines up with the centre mark and the one a few teeth to the right lines up with the white mark made on the piece of metal at 1 o'clock
Hoping once I've turned it it will become clear.
Believe me, I know this must be similar to watching a one armed, lazy eyed child attempt to tie its shoe laces in a high wind.
Thanks.
Thanks.
) is driven off the pump to the cam.
