Im feeling, only on rough roads, like the sterring column has some free movements.I change all the front end parts, inluding steering rack bushing. So must be something in the column itself, what can it be?Where can i find those parts?
Steering loose...
if its not the rack bushes - which you said you have replaced
i had similar movement on my LC colorado. same steering system.
with help of a friend we had checked all the tie-rod ends and the rack bushes.
i had the front of vehcile on axle stands, both wheels in air and got friend to push/pull on either side of one of the wheels so i could hear and feel the "clunking" that i first noticed driving on rough tracks slowly offroad (felt through steering wheel),
and we tracked it down to top of steering rack, wheere the steering wheel joins it
on the drivers side of the rack and facing towards the rear, below where the steering link from steering wheel joins - there is a big lock-ring with hex shaped insert.
i loosened the lockring and slightly tightened up the inner part - this stopped the knocking. it is some form of preload on the rack.
careful how much you tighten it, it only needed a small bit
you may need to back-off the tightness after winding it in. and also check to make sure steering doesnt "bind" after adjustment
here is similar issue on a subaru
http://www.subaruforester.org/vbulle...uestion-24067/Last edited by andycook; 28 February 2011, 15:53.Landcruiser Colorado
Sub. Forester
[QUOTE=andycook;701349]if its not the rack bushes - which you said you have replaced
thanks, will chek it out.
