Had a good look through the Autobox problems via the search but didn't find anything quite like my problem.
After giving the Surf a nice valet I decided the engine bay looked a bit dirty so decided to jet wash it to brighten it up a bit. Now this may or may not be connected but does seem like a bit of a coincidence, since doing this the Surf (1996 3rd gen KZN185) won't seem to go into the final gear or lock up I think it is called? Allways used to really drop revs at around 55mph but now does not do this and sits in 3rd or whatever it is before the last gear. All other gears work fine including reverse etc. Overdrive still works as if I press the o/d button it changes down immediately, oil changed last year and at right level etc.
Just thought maybe I had gotten some water somewhere where it wasn't supposed to be. Anyone know which relays or plug connectors or associated wiring for the box is in the engine bay worth checking? Or any other ideas?
Thanks
Pete.
Thanks
Pete.
