Just thought i'd post these up as its kinda interesting in a warped way :/
I've had my surf for about 6 years or so and never had a problem with it untill last winter when it suddenly used a bit of coolant.. and then a bit more.. using about a good litre on a 150 mile journey.. so not wanting to strip it down on a cold wet driveway in sub zero temperatures i stuck some 'K Seal' in, and wow it actually worked, in fact i completely forgot about the problem.. that is untill.. its ###### winter again!! Only this time it properly pressurised the expansion tank and someone pointed out that my truck was ''foaming'' and sure enough, there was ''truck puss'' streaming out from the expansion overflow lol
Anyways, i ''whipped'' the head off, and on closer inspection, it seems that there are cracks between the valves (and several on all the combustion chambers, but that's not really an issue i think) and these have obviously crept into the cooling system
New Head for me, which sucks!!
Anyways, here's some pics
i wonder if my foray into alternative fuelling helped speed up this process..
trucks on 149,000 kilomiles (neither miles or kilometres as the 33" wheels throw the milometer out lol)
Mind you.. i was CURSING not having diff locks when i stupidly started reversing off a steep cliff into a fast flowing gorge in the middle of the night a couple of years ago and it did the ''italian job'' thing.. except i had one rear wheel gone over so the other one was just spinning and the opposing front wheel was about 2 foot off the ground so the other one was spinning heheh not an amusing situation
