hallo my fellow surfers just changed seals on my kzn 130 3ltr power steering pump cog & 2 bolts system and it don't work .YYY is this :tired
anybody
when engine is running it spits fluid out of bottle and pump doesn't make a noise.so ya think its only air me old "bushwhacker" CheersOriginally posted by BUSHWHACKER View Posthallo are you saying the steering doesnt work or is very stiff?
theres most likely air in the system so you need to jack both front wheels off the ground with the engine switched off turn the steering wheel from lock to lock about 20 times to expel any air in the fluid and then top up if necessary.
theres most likely air in the system so you need to jack both front wheels off the ground with the engine switched off turn the steering wheel from lock to lock about 20 times to expel any air in the fluid and then top up if necessary.Cheers tonynOriginally posted by TonyN View Postlol, huh?
As Vince said, it'll take just a little longer than you think is right, and start to think you've done something wrong, to get all the air out.
Keep turning that wheel!!
ILL put it back 2gether again on monday, thought i was going mad. Getting good at taking pump on off on offOriginally posted by BUSHWHACKER View Posthallo are you saying the steering doesnt work or is very stiff?
