In the morning car will travel 200 mtrs at 5kph and then slowly starts to pick up. new turbo fitted, tps changed, once warm still slow to accelerate
new ecu fitted,timing + valves checked,exhaust removed-no diffs, pressure leak tests ok, Sometimes will perform as if all is well
the ones circled are what i used
