the garage pressure bled my brakes (twice) and it passed MOT ok, brakes are good but it seems to dive at the front a bit, the problem is the massive amount of travel on the pedal.
I replaced the master cylinder and both front calipers, rear shoes are adjusted and no leaks in system, mechanic said system held good pressure but because I have braided lines he couldn't clamp and isolate the problem.
I'm now suspecting the proportioning valve has seized with the truck being laid up for months, what do you guys think?
Could the valve not working properly cause this problem with the pedal?
Am I looking at £90 for a new one or would one from a breaker be ok?
