Hi ive got a problem on the 4runner that keeps coming back.Its getting air in the hydraulic fluid which causes the pedal to only come back up half way, then it crunches gears ect. Ive changed the master and slave cylinders and have just changed the flexy pipe but after a fortnight the problem has still come back,All the bits are new from Roughtrax .Ive checked all the joints are tight obviously and nothing had been changed /adjusted before hand. I have found another cylinder inline that i have now tempereraly bypassed so i can still use the car but am unsure what it does, it has a plunger/piston inside .Does anyone know what it is , does it matter if its bypassed ,where can i get one from if i need one . And i still dont even know whether this is the problem.
Has anyone ever had this problem and how did they cure it.Thankyou in advance David
