Hi guys, I know this looks like a repeat of the previous threads but surf was overheating and losing loads of coolant. Got the head off and no sign of damage to gasket etc. Could it be losing water thru the turbo (intercooler) or will it be a cracked head? Help, advice please, cheers.
head or turbo?
Crack will be above the precoms. I have replaced a total of 4 cyl heads on a 1KZ over the last 10 years and 3 were as a result of catastrophic cooling system failures. This said 2 have failed this week and each are early production and have covered 225km
lol, is that all? I've done :goes to check invoices: 3 3.0's (2 KZN185, one ZN130) and 3 2.4's this year, and and about 10 3.0 and 25 2.4's in 4 years. All but one 3.0 head cracked in the same place as the 2.4's between the valves, and one was cracked by the valve guides.Originally posted by 4thsurf View PostCrack will be above the precoms. I have replaced a total of 4 cyl heads on a 1KZ over the last 10 years and 3 were as a result of catastrophic cooling system failures. This said 2 have failed this week and each are early production and have covered 225km
(oh, and for those keeping count, also 3 3.0's have been headgaskets, 0 2.4's were..)
