Bl**dy thermostat
  • Bl**dy thermostat
    Trying to change the Thermostat after putting a new rad in, undone the two bolts and the housing will not move. Any tips on how to remove the housing will be much appreciated.
    if i remember correctly there is a bracket aswell fixing the pipe to the block aswell
      I could not see a bracket, but I will have a look, there is a bracket fixing it to the ATF hoses, which I have undone.
      Thanks for the quick reply.
        definitely a bolt holding the bottom of the pipe to the underbits, 12mm. H
          It's under the above mentioned bracket.
            Found it, but it is not the original bolt, the top one was 12 m and the bottom one was 11m. Guess what. I have every size spanner except 11m
            Sods Law.
              If you have imperial try a 7/16".
