Trying to change the Thermostat after putting a new rad in, undone the two bolts and the housing will not move. Any tips on how to remove the housing will be much appreciated.
Bl**dy thermostat
Originally posted by peter026 View PostI could not see a bracket, but I will have a look, there is a bracket fixing it to the ATF hoses, which I have undone.
Thanks for the quick reply.It's under the above mentioned bracket.Originally posted by Hazzo View Postdefinitely a bolt holding the bottom of the pipe to the underbits, 12mm. H4x4toys.co.uk - Keeping you on and off the road...
