hi i have a 3.0 td manual surf.
it has recently got a serious problem with the idle control, and stalling.
basically it seems ok when you first start it up, but then drive it 5 mins down the road and it wants to stall every time you put the clutch in/pull up at junstions, it either just cuts out, or properly chugs trying to stay alive, power steering stops working, and then a puff of smoke comes out the exhaust.
if it does decide to stay alive, then the idle is very low, such as around 500rpm.
it started doing it intermittantly a while ago, but now it is getting much worse and stalling pretty much every time.
you can basically coax it into not stalling, by feathering the throttle to stabilise the idle when u come to a stand still.
one other thing i noticed is that when you are driving, the off-on throttle action is very jerky. so it is hard to come off the throttle and get back on it without it jolting.
(maybe tps- altho i disconnected it to see if it made a difference, and it stopped the throttle from working all together)
what on earth is it, as it really needs sorting asap.
thanks
nick
thanks
nick
