Just seen mine and there are cracks in between the valve ports. The worst one is raised on one side, so can assume the crack runs all the way through the block to the cooling channel.
There are also corresponding marks in the cylinder nearest the bulkhead showing water invasion.
Does a failing head make any noises? Mine was abit "buzzy" prior to it failing. If there is an indicative noise it may be of help to others, especially buyers, in the future....
Any thoughts?
Any thoughts?
