i too had a similar problem with car pulling done the exact same thing as you but in the end it turned out to be the tyre itself. check to make sure there are no bubbles in your tyres, this is what happened to mine and only found out when i looked closer. if it does have a bubble of some sort then you need a new tyre end of!!!
hope you get it sorted
regards me
regards me
