Air con gas
  • Air con gas
    Hi, does any one know the weight of gas (grams) needed to recharge the a/c on a 95 ssrx 3.0 TD. We looked for sticker that says how much gas is needed but couldn't find one and the local toyota garage couldn't tell us as it's an import.
    I bought the standard gas top-up last week at Halfords. It cost £49 but you get £10 back if you return the gas bottle after.
    You must read the instructions fully before you do it, but it took me abot 4 minutes and my air-con is now too cold to run on full fan eve on the hot day recently. The best £39 I have spent in ages...
    http://www.halfords.com/webapp/wcs/s...egoryId_165632
    Bud
    I told the butcher I'd give him £25 if he got the meat down off the top shelf. He said he couldn't. The steaks were too high.
      It'll be the same as a UK 4Runner shouldn't it?
      They are all 3.0L I believe?
      I've got a plan and it's as hot as my pants!
        3rd gen air con question
        3rd gen, P reg -
        can I buy a can of cold from Halfrauds and just squirt it in?
        will the fitting provided fit the surfs fitting?
        do I need to consider new seals?
        do I need to vacuum the system first?
        anyone?
          When I had mine repaired professionally a good few years back the guy said it should take about 700 -750 grams from empty. If you are using the Halfrauds kit just make sure you don't overfill it.
          Mike G
            Originally posted by legendgamesmaster View Post
            3rd gen, P reg -
            anyone?
            Yes
            Yes
            Possibly, depends if they're leaking
            No
            Mike G
              Thanks for the responses. A mate who does air con was doing the work but said he couldn't complete the job without knowing the exact weight of gas. There is a yellow sticker in front of the radiator which we suspect is to do with the air con but unfortunately we can't read it. If anyone with a 3Lt 4 runner could have a look under their bonnet and see what the sticker says i'd be ever so grateful.
                I think it's probably to say the system has been upgraded to take R134 gas as originally they would probably have had the now banned R12 when new.
                Mike G
                  Don't p!ss about, take it to KwikFit, £49.99 for a guaranteed cooler system.
                    Nah, any 3.0 truck will have R134, its only 2.4's that have the old stuff.
                    Does your mate not have specs for a 4Runner? I'll have a look at our tomorrow, or just take it to Quack Fat as suggested!
                      According to the Toyota FSMs...
                      2nd gen takes 700g +/-50g (R134a systems)
                      http://www.ncttora.com/fsm/1990-1995...c/refriger.pdf
                      3rd gen takes 650g +/-50g
                      http://www.ncttora.com/fsm/1996/SIL/...eflin/repl.pdf
                        Thank's for the info.
