sorry guys
i know this has been covered numerous times but my rear window doesnt operate at all both outside with keys and with button inside car. i have stripped the panel off inside the boot since i cannot open the boot at all. i have also unscrewed the bottom rail across the boot where the carpet is attached. can you tell me what to look for inside the boot panel where glass is and where to look with the carpet off. ive tried the manual movement of the window wiper arm but all i hear is clicks from the relay both with keys and button inside car for up and down operation. im ready to torch this thing!!!!!
any help is appreciated and i have looked at recent posts but im a little stumped on wiring positions. if you are describing what to do please position yourself as if your inside the boot of the car looking out the rear window this way i will know exactly where to locate wiring etc...
i have tried to wriggle wiring both on the lock inside boot and other plugs but i dont want to make things worse....im too gentle
i did look underside of motor to see wiring leading into boot...its covered with a plastic trunking. im sure theres more than 1 trunking under car so where do i start from? i dont have a volt meter or any such tool to check for breakages etc...
kind regards me
kind regards me
