hay all the solonoid bit in the actuator am i right in saying its under a small disk like piece with a circlip, and im thinking this could be the reason for my problem i posted the other day because i was really clever and removed the plate and a cilinder sprung out i pushed it back in after some amount of oil coming out and am now suffering with intermitent revers and pullling power many thaks
transfer shift actuator
yep TonyN will be your man and he is in Basingstoke.You can get his contact details from www.4x4toys.co.uk you will have to ring his mobile number as i don't think he has a landline sorted yethttps://www.facebook.com/groups/henpals/
actuator
Hello gents, i've been restoring a surf kzn 130 over the years and just rejoined this forum to try and solve an actuator problem and i found this thread my problem might be the same as yours - I can't engage 4wd due to what an auto electrician has diagnosed as a faulty actuator connection! Are you having the same problems? He says the actuator is like a wiper motor with a disc connection thingy it can corrode and give problems? I don't know really is it worth taking apart or getting a second hand one. It's spoiling a great car at the mo. Good luck with yours
FourSix
