Brake Calipers 2.4/3.0
  • Brake Calipers 2.4/3.0
    Hi Surfers,
    Just a quick question. I have a lazy caliper on the front of my 2nd gen 3.0. I`m looking to overhaul both calipers this weekend. Just in case they are too far gone on either side, are they the same on a 2.4?
    Cheers, Ben
    yes both 2.4 and 3.0 are the same
      Thanks mate,
      I guessed they might be but info is much appreciated! Always best to check!
        always best as you say if your not 100% sure
          In case you are sourcing second hand make sure you aren't getting them from a pre-facelift 2.4 as they are different; as are the discs.
          The post facelift 2.4 and any 3.0 are the same.
          Just thinking, if you are buying new you need to be wary of the same thing as Roughtrax list both too.
          Thanks,
          Ray.
          I've got a plan and it's as hot as my pants!
            Thanks,
            Ray.
            Correct. The change was 8/'91. Bigger discs, calipers and different pads.
              Ok guys,
              Once again, all the info is greatly appreciated! Have a great weekend!
              Ben.
