Hello, i've used the search function and I thought i'd got an answer for my problem but now i'm not too sure.
When turning the steering wheel, especially when cold, the steering wheel vibrates and makes a humming noise. From searching i'd found out that maybe my power steering belt might be loose and needed tightening up. Having looked underneath it I can't seem to find a power steering belt so I had another search and someone mentioned that the 3.0l doesn't have a belt only the 2.4 instead it has a pump.
So if it does have a belt I might need to just tighten it, but if it doesn't what could be causing the vibration?
I do have what looks to be a leak from underneath the engine but it looks more like engine oil not power steering fluid.
Hope someone can help
thanks
Dan
thanks
Dan
