Hi - I've just noticed a crisp new crack at the base of the rear drivers side coil spring. Too enthusiastic in reversing up a steep rough gradient in 2 wheel drive with much wheel spinning and bouncing, I think..... No noticeable degrade in handling on road use, but obviously it needs to be replaced soon. Truck has a 2 inch lift, Rancho 5000 shocks (hard) and 285x16 tyres/wheels.
I'm not sure if I need to buy and replace both rear springs to maintain match. Also uncertain about the work involved in compressing springs and extracting/replacing them. Will it require special springs with it being lifted 2" and how can I be certain that it's a 2" lift and not higher/lower than that? I only have the previous owners verbal on the lift. Are special tools needed (spring compressors)? How difficult is it for a diy job with average spannering skills?
Any comments or suggestions on what might be involved will help and meantime, I'll run a search on this forum for what's involved in the repairs.
Thanks.....Keith
Thanks.....Keith
that is the proper way, but with man enough compressors
! But I'm usually changing shocks at the same time and doing other stuff so easier to just take it all apart.
