Today I was greeted with a leeking fuel pump. First problem in 2 years fortunately. It is leeking by the large nut/sender unit fuel shut off valve I think. Can this be sorted without removing the pump from the truck . By removing the four cap head bolts and the fuel inlet pipe. Then hopefully replacing the o ring/s. I think this is because of using veg oil? Many thanks for any advice.
Leaking fuel pump
I believe that this is a problem with using a high concentration of veg oil and can easily be replaced. I seem to remember Apache posting about this a short while back. I'm sure if you search you will find the answer,
Cheers, Nick"The force will be with you, always!"
Fuel pump
Hi Nev hopefully its a case of removing the air box and fuel line/s moving various cables out of the way removing large nut then the 4 cap heads from the top casing/cap then remove switch then O ring replace with new then large rectangular o ring and reassemble bleed the system. Just need to source new rings.......I hope
Originally posted by ALZ View PostToday I was greeted with a leeking fuel pump. First problem in 2 years fortunately. It is leeking by the large nut/sender unit fuel shut off valve I think. Can this be sorted without removing the pump from the truck . By removing the four cap head bolts and the fuel inlet pipe. Then hopefully replacing the o ring/s. I think this is because of using veg oil? Many thanks for any advice.
KZN130 fuel pump
Went to Toyota all they could offer was an exchange pump. So went to a fuel injection specialist and picked up a service kit. A Denso overhaul kit with every gasket, screws ,copper seals,numbered o rings and diagram. Denso serial no 096010-0630.
Kzn 130
had the exact same problem last week and im using veg oil too....my mechanic just tightened it up and hey presto all ok....
If you tighten the large nut be very carefull because inside the pump the casing is on a plastic lug locating on a peg, if that turns it will sheer of and the bits will drop into the pump. Its is there to prevent sheering off the wiring inside.
