Today I was greeted with a leeking fuel pump. First problem in 2 years fortunately. It is leeking by the large nut/sender unit fuel shut off valve I think. Can this be sorted without removing the pump from the truck . By removing the four cap head bolts and the fuel inlet pipe. Then hopefully replacing the o ring/s. I think this is because of using veg oil? Many thanks for any advice.
Leaking fuel pump
I believe that this is a problem with using a high concentration of veg oil and can easily be replaced. I seem to remember Apache posting about this a short while back. I'm sure if you search you will find the answer,
Cheers, Nick
"The force will be with you, always!"
Fuel pump
Hi Nev hopefully its a case of removing the air box and fuel line/s moving various cables out of the way removing large nut then the 4 cap heads from the top casing/cap then remove switch then O ring replace with new then large rectangular o ring and reassemble bleed the system. Just need to source new rings.......I hope
I had the exact same problem last week and im using veg oil too....my mechanic just tightened it up and hey presto all ok....Originally posted by ALZ View PostToday I was greeted with a leeking fuel pump. First problem in 2 years fortunately. It is leeking by the large nut/sender unit fuel shut off valve I think. Can this be sorted without removing the pump from the truck . By removing the four cap head bolts and the fuel inlet pipe. Then hopefully replacing the o ring/s. I think this is because of using veg oil? Many thanks for any advice.
KZN130 fuel pump
Went to Toyota all they could offer was an exchange pump. So went to a fuel injection specialist and picked up a service kit. A Denso overhaul kit with every gasket, screws ,copper seals,numbered o rings and diagram. Denso serial no 096010-0630.
Kzn 130
If you tighten the large nut be very carefull because inside the pump the casing is on a plastic lug locating on a peg, if that turns it will sheer of and the bits will drop into the pump. Its is there to prevent sheering off the wiring inside.
