Hi,
We have an intermittent problem with our new Surf. It drives well and runs fine most of the time but every now and then the engine stalls without warning (which is no fun in an automatic I can assure you
It happens once she's fully warmed up, and so far its only happened when we are slowing down to stop or crawl. The engine cuts out, the Check Engine Light comes on and she won't start back up again for 10 seconds or so. Then she fires and runs perfectly
I've ordered a new set of filters from Milner as they are well overdue for replacement and I'll give the vacuum hoses a once over today, but is there anything else I should be looking at? Or more to the point at the moment, is there anything else that's relatively cheap that I should be ordering at the same time?
I don't want to pop the bonnet next weekend and discover that the fault lies with a 50p grommet that's gonna take a week to arrive by mail. I'd rather order it now and replace it just in case......
Any hints or advice would be gratefully received, especially from anyone out there who has had similar problems.......
)It happens once she's fully warmed up, and so far its only happened when we are slowing down to stop or crawl. The engine cuts out, the Check Engine Light comes on and she won't start back up again for 10 seconds or so. Then she fires and runs perfectly
...... an experience I'd rather not repeat.
