New brake pads
  • New brake pads
    Hi,
    I have a horrid metal on metal scraping sound coming from my front brakes so I'm guessing the pads need changed quick. I was going to get the set from roughtrax till I found that after delivery and vat it was going to cost me £27. I've found these on *bay: http://cgi.ebay.co.uk/HILUX-SURF-3-0...#ht_882wt_1042 Does anyone know if they're ok?
    I've never changed brake pads before but as I'm skint I don't fancy getting fleeced by a garage - is it fairly easy? How likely is it that I've damaged the rotors - will they need replaced - is that easy? Thanks for help all!
    Never heard of them, play it safe & get the roughtrax ones.
    For the sake of £8 its not worth it.
      I doubt theres to much wrong with them, compared to any aftermarket pad, but they arn't all equal and you normally get what you pay for.
        Aftermarket ones can sometimes squeek as not always a perfect fit. Toyota pads are around £25. Its a no-brainer.
        Windows 7 was my idea!
          And buy a pin kit.
            And buy a pin kit.
            You'll be lucky, he's totally skink & worring over a few quid on the pads.
              Skink? Thats a clever lizard changing brake pads.
                LOL, i would'nt mind but "K" is nowhere near "T".
                Its been a long day.
                  Unless it's thon Tunstall lassie?
                    it seems like it is on your keyboard tho
                      I'll change them for you if you get pads and pin kit. I'm in Denny, Stirlingshire.
                      Alan
                        hmmm might well take you up on that offer! Much appreciated. Maybe you'd give my truck a good once over while you're at it (paid obviously!)? When would be a good time - bearing in mind my brakes would probably appreciate sooner rather than later!
                          If you find uneven wear on the pads you will need a caliper rebuild. Scored discs will have to be machined or replaced depending on condition.
                            When i did my brakes last week,it was the first time i have ever done a complete brake change so wasn't 100% on what i was doing.I had a mate working in the unit next to mine who came out just to give it the once over and help bleed the brakes for me.
                            Now i know what i'm doing it wont take as long when i need to do them again
                              Right - I've taken all your advice and the plunge! I've ordered the roughtrax pads, discs and pin set - phew what a splash out session!
                              Andy if you're still on for fitting them I'd be eternally grateful. I think the bushes on my front suspension are knackered too and would really appreciate your opinion on whether or not it's worth replacing the whole suspension with the desert fox lift kit from roughtrax (and if that's all I'd need). The rear suspension looks like it's sagged too and last time it needed it's MOT the guy put gaffer tape on the bushes to stop them crunching - not ideal I know. I suspect my truck might be a heap of sh 1 t and it makes me want to cry.
