Just started to take the cambelt off to have a look at whats going on inside the timing case.
Basically my injector pipes are fitted incorrectly and the pump is near 180 degrees out.
Do I need to remove the timing gear that connects to the injector pump to put things right ?
Heres some pics showing how the marks are right now (and yes it does start and run, just about
The cam is 1/2 a tooth out, and the pump mark is almost opposite where it should be.
)The cam is 1/2 a tooth out, and the pump mark is almost opposite where it should be.
