Sorry this is a bit long winded, but I need to thoroughly explain the fault.
My KZN185 has developed a problem, where by when I reach a speed of 55 and over, the truck vibrates. The best way I can explain it is it feels like I'm driving over a grooved surface. The faster I drive the more pronounced the vibration. Oddly enough, when I remove my foot from the accelerator, or put it in neutral the vibration increases dramatically.
I had notices a leaking front seal on my centre diff. and assumed it was related. I had it to a garage today, as I'm rather busy and they could not find anything physically wrong with the drive components and checked all the oil levels of the diffs.
To no avail.
I then thought that it might be related to the transmission as it does clunk a bit when engaging from neutral to drive or reverse. Level was a tad low, bottom of the scale, the colour was nice and red and no smell of burning.
I also sometimes hear/ feel a slight knock when setting off from a standstill.
I'm not really sure what to look at next and my thoughts are that I'm going to use a process of elimination, i.e. remove front drive shaft, try, replace, remove rear, etc.
Only one other thing to mention.
This fault has only started after I recently fit a 2" suspension lift. Double checked everything and all is tight. Coincidence maybe ???
Any thoughts would be much appreciated.
Sparks...
To no avail.
Sparks...
don't want to make things too easy for you, you have to work for the answer
