Hi well as title says very loud grinding noise coming from vehicle once i have drivin apporox 6 or 7 miles, it is linked to how fast i am going you can feel it through the car. As you slow down the noise slows down untill you stop, the you can start off again striaght away and it is ok for about 200yards max and the grinding noise comes back.
I did have a problem with my front diff but i have changed it and the O/S/F hub and wheel bearing twice and the noise still comes back. I have checked both propshafts no play to be found, the noise seems to come from the centre of the car "Transmission Tunnel ". I put it in 4 wheel drive and the noise goes but as soon as i go back to 2 wheel drive the grinding starts again.
Had a quick think and looked under again as i thought no "TonyN" hideing under there with his 4" GRINDER. Any one got any suggestions.
Hilux-Bob
Hilux-Bob
I knew you wern't serious, or you'd have said 9".....
