I have a problem with the oil level warning light illuminating on my 4 Runner after a couple of miles, then it goes out and stays out. It does this every time I use it from cold. There is plenty of oil in it and the oil pressure is good. I went to Toyota and ordered a replacement switch which fits to the side of the sump. The cost £1.80 as I thought was a bargain, but when I went to pick it up it was actually £180 + vat, so I left it there. Any body else had similar problem, it may not even be the switch that is faulty.
Rob
Rob
