I have had the current Hilux Surf over two years with few probs ( then I don't do many miles).
Now, after four months parked off road it started first time so the cold has not done the battery in.
However, I cannot get the bonnet open to check radiator.
This is the first time I have had this problem.
The catch thing which you normally have to press in a bit at the front of the bonnet does not seem to be there at all - perhaps it only appears after the release mechanism below the dashboard has been pulled ?
Anyway, when I pull the release thing inside the car, there is a slight noise but the bonnet remains firmly closed.
Any suggestions as to how to open the bonnet please ?
crowbar
