Hello!
I recently purchased a '94 Hilux Surf SSR-X. Of course it was poorly maintained before I got it at 89,000km. First few tanks of fuel gave me about 20MPG. I did some work, and now the MPG are much lower, about 16. Here is what I did to the truck, any ideas what happened?
new tires (from stock size 265/70r15 to 31x10.5r15)
new fuel filter (ran 50/50 ATF/diesel in filter when changed to clean injectors)
changed oil and gear oils
changed air filter
added 1/3 can of Seafoam (http://www.seafoamsales.com/motor-treatment/index.html) to the fuel tank
new batteries
greased drivetrain
I know the tires would change the MPG, but only slightly as they are only 4.8% larger. I've lost nearly 25% of my mileage efficiency! Did I damage my injectors with the ATF and the Seafoam? How can petroleum based prodcuts wreck injectors?
Thanks in advance for your ideas!
changed air filter
new batteries
greased drivetrain
At least she's consistently bad though.
