Hello there everybody,
Am new to the forum and hoping someone can help me.
I have a Nreg surf ssr x 3.0,it sounds like it has a blow from the exhaust manifold,when i investigated i couldn't find a leak in manifold/egr etc..but the sound seems to be coming from inlet tract,i took out the sensor on airfilter(air temp) i think..and there is pressure coming out and not vacuum?
I put a vac guage on manifold and it's not pulling any vac.infact slight pressure(this is in tickover) ocassionally the needle would flicker back to 5inches of merc and then back again.did a compression test and got 540 all across the cylinders,but don't know what they should be,could it be sticky inlet valves,can the turbo gunge up and overboost,or egr stick open?? turbo looks very oily not sure if it's from breather though.Had a look under main butterfly and it's got loads of thick gunk in there!! She runs o.k no smoke etc....
thanx andy
thanx andy
