I recently contacted http://www.allisport.com in reference to getting an intercooler mod fitted to my Surf, they were very fast in replying to my email, thought some of you might find the information helpful as I have seen quite a few people enquiring about after market chips and intercoolers. Ss of yet I have not had one fitted, I am however giving it serious thought... just trying to work out the time to get my vehicle upto Gloucester.
Subject : Re: Enquiry from Allisport.com
Hi Keith,
Thanks for the enquiry, the Surf is a tricky one to do an intercooler kit
for due to the lack of space.
It is possible if a little complicated to install a kit, but the cost due to
extra pipe and labour is higher.
The other consideration is that the engine has electronic management meaning
that you need to set the fuel to match an intercooler. This can be done
using an electrinic tuning unit which acts in a similar way to a chip but is
wired into the loom externally. As the Surf is an import, I will have to
check the availability of the unit.
If available it will cost £390+vat and can be used on it's own to gain
around 20% more power and torque.
I hope this is of interest and look forward to hearing from you.
Best regards,
Andrew
Hi Keith,
Best regards,
Andrew
