right im making slow progress on the kzn130 conversion. latest issue. sometimes when turn the ignition on we get the engine check light and glow pug light come on. but the glow pug light is flashing in time to the diesel pump clicking (argh). if this happens when cranking we get smoke out of exhaust and it tries to fire up. other times no check light, glow plug light and clicking and will not try to start. so far only had it run for about 2 seconds then cut out. has fuel, good batteries and new fuel filter.
weird electrical issue
Fried ECU was my initial thought. But if 100% of the wiring has been swapped over, it should be OK?Originally posted by Apache View PostIt does sound like an earthing issue - or an ECU fried by an earthing issue.
100% of the wiring was swapped wasn't it? Internal, external, dash, ECU, everything...Do you know that, with a 50 character limit, it's
