HI GUYS last week asked about auto gearbox over heating temp gauge going up to red when towing so changed gearbox oil flushed rad and replaced coolant . at weekend set of to selby towing caravan after about 1hour just off motor light came on 4 about 5 mins then went off temp gauge never moved but on way back ligt 4 oiltemp came on and temp gauge nearly in red left over night checked rad put 1liter of fluid in to get back to level expansion tank low as well been suggested new rad needed going to cornwallsoon or maybe not need advice /help
hodgkinson
Well lets start with the obvious.Originally posted by hodgkinson View Postit's a 1994 ssrx td auto i live in morley not sure about gen imported
You've changed the transmission oil, CHECK.
(Is it at the correct level) i.e engine at running temperature, truck on a level surface & gone through the gears a few times to fill the pumps, then checked its at the HOT mark.
You've changed the coolant, CHECK.
Did you change the thermostat as well & are you 100% sure you got all the air out of the system, sound to me as if there is still air inside or a leak cos you've been topping it up.Last edited by si tate; 15 June 2009, 18:17.If its not broke don't fix it.
Hi Hodgi,
Fill in your profile correctly, it helps us to diagnose probs better.
Now, when towing, are you uphill?
Have you changed the thermostat?
Have you bled the cooling system?
How much water does it use? if any.
Have you checked the auto fluid levels?
Leeds to Selby is near flat, should'nt have
any probs, Flushing radiator might help,AIR LOCKED?
Hope this helps.
Gman.
See post below.Last edited by GRASSMAN; 15 June 2009, 23:22.If it aint broke, keep goin' till it is.
Don't take no notice of those 2 mate.You will be better off adding your truck details to your profile so we can answer any questions quicker for you.For the thread title put a short brief detail of the problem like WHICH COOLANT or COOLING PROBS rather than your surname.Hope you get the truck sorted mate and just take the #### out of those 2 as they can take itOriginally posted by hodgkinson View PostTHANKS FOR THE SUPPORT SI taken car into britiannia cooling later to today
see if they can sort out. what the other two guys problem like you said i'am new to the game .https://www.facebook.com/groups/henpals/
