Hi, had problems with hilux loosing water from radiator, it was pushing out through overflow pipe back into reservoir, that was filling then overflow into engine bay. Thought radiator had a hole in top near neck so put new radiator in & new cap. Also had full service. Came down M1 last night and same thing has happened, water is coming out from radiator overflow and emptying radiator,Has anyone any ideas?...
3.0 l KNZ185 LOOSING WATER...HELP!!!!
Oh dear,
Mine did the same, it would tick over all day without any problems, but if i drove it around it would do what you`re saying, tried flushing cooling system, still was the same, the top hose was rock hard, cooling system pressurised.
so headgasket would be next culprit, pulled the head off, did`nt look too bad, although there was signs of rust on it so something leaking, anyway i decided to play safe, i have replaced the head with a new one, not recon! new radiator (this had been repaired), headgasket headbolts, thermastat etc.
now runs great....
maybe worth going to a garage for a sniff test on the cooling system, see if there is any fuel or gases in it before you start buying bits..
