Hey all, just recently my sisters '93 SSR-X has started holding onto gears too long. I've checked the gearbox oil and topped it up (was only slightly low and unburnt), and checked and cleaned all the earths i could find under the bonnet and inside by the fusebox.
I discovered a bared wire leading to the ECU which was taped up, and i found on here about how to get the flash codes up and this is where my problem lies.
When i short the diagnostic socket, i get both the engine check and o/d off lights flashing constantly, with no break. Umm, help???
. Also tried disconnecting both batteries with no effect.
