Found the budgie hiding in the engine bay.....
Bit of a crap design me thinks...after buying another maniflod that was flat and fitting with cheap (compared to toyota) manifold gasket i had a budgie in the bay and here's why.......
If you look just left of port 3 you can see a faint round mark just before the flat shiny bit gets recessed bake and looks rough and lumpy.
Thats the impression left by the gasket copper rivet.
If you look between ports 3&4 you can see same impression.
Here's the gasket with copper rivet
Now the problem, the compressed gasket measures 0.55mm the rivit measures 1.95mm.....
Can you see where i am going....?????
No mater how tight the manifold studs are if the rivet does not sit in the rough recessed area there is no way you can compress the rivet down and make a good seal.......
here you can see between the gasket plates the blow out residue.....
so me thinks thats why she made the chirrping buzzing noise as the gasket vibrated when the gasses passed through them....
Gunna make sure that don't happen again.....
Paul1566
Paul1566
