just had a tow bar fitted and when we lifted the boot carpet the off side rear corner was wet, had a look under the wheel arch no signs of anything, checked the off side rear window seals and all looks ok, did notice the rear window seal inside wasnt fitted all the way down correctly but looking at the car with the window up and everything shut carnt for the life of me think how water has got in that way. any ideas or has anyone had a similar prob any advise woiuld be ace as i want a beast of a car not an fish tank...
water in boot
Originally posted by fireflyjust had a tow bar fitted and when we lifted the boot carpet the off side rear corner was wet, had a look under the wheel arch no signs of anything, checked the off side rear window seals and all looks ok, did notice the rear window seal inside wasnt fitted all the way down correctly but looking at the car with the window up and everything shut carnt for the life of me think how water has got in that way. any ideas or has anyone had a similar prob any advise woiuld be ace as i want a beast of a car not an fish tank...Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
Originally posted by fireflyjust had a tow bar fitted and when we lifted the boot carpet the off side rear corner was wet, had a look under the wheel arch no signs of anything, checked the off side rear window seals and all looks ok, did notice the rear window seal inside wasnt fitted all the way down correctly but looking at the car with the window up and everything shut carnt for the life of me think how water has got in that way. any ideas or has anyone had a similar prob any advise woiuld be ace as i want a beast of a car not an fish tank...ScubaSurf
The place to be is under the sea
cheers the cable entry poin he used was on the opposite side so thats a no no, will check the body mounts tonite when i have a spare bit of time at work..., i think koi may have it though the seal at the BOTTOM ot the tail gate is loose in the right hand corner where the water was so gunna stick that on with silicone and see if these things do the trick
Dave.if a politition is talking its lying
