Ok i have read all the threads about chirping and whizzing......
Am i right in saying that the turbo kicks in at about 2000 - 2500 rpm ?
Cus after all the work i have done on my surf a chirping noise is all i want and yes i got one....sounds like you just blew a budgie up like a whoopie cusion and squeezed it whilst sticking its beak in the spokes of your sisters barbie tricycle....
New head, water pump, cam belt, tensoiner, turbo reconditioned blah blah blah also no a/c or egr any more, made plates to blank off the egr on the inlet and exhaust manifold....
All running fine and pulls like a train but between 2500 - 3000 revs i get a chirping noise that disapears at over 3500 revs.....
Only does it when moving be it light or heavy load same sound...
May have to strap the missus to the bonnet to listen a bit closer tomorrow... or find a tiny tiny person to sit under the bonnet.....
Suppose it could be turbo pressure forcing its way past the gasket where the egr valve used to be as i used the old one when fitting the blanking plate but did not think turbo pressure was that great ?? plate is 1/4 thick steel...
Oh well surfing is fun isn't it and i don't even own a wet suit.....
Paul1566
Paul1566
